Einleitung
In order to complete this repair properly, you will need teflon tape to seal the threads of the safety valve. Although this step seems unnecessary in some cases, it will make your compressor run more efficiently without excessive starting and stopping. The replacement of safety switch is straightforward.
Was du brauchst
Using the medium crescent wrench, unscrew the safety valve by twisting it counter-clockwise.
Apply teflon tape to the replacement safety valve.
