Einleitung
This guide is a quick solution to fix worn out roller skate wheels! Rather than spend lots of money on a new pair, just replace your old wheels to get your roller skates spinning smoothly again!
Was du brauchst
Use a 13mm wrench to loosen the nuts in the center of the wheel(s) that need to be replaced.
Remove the nuts from the axel.
Slide the wheel off the axel and check your axel for dirt, grease, or hair.
Clean the axel thoroughly.
Place the wheel on the axel.
Thread the nut onto the axel on top of your wheel with your fingers.
Once you have it on there tightly, loosen it a little to allows your wheels to roll smoothly and not rub. Test your wheels by spinning them with your finger.
This is a simple replacement with very easy-to-follow instructions. If you followed all the steps exactly, you will be skating again in no time!
