Einleitung
If the oven fan stops, or starts squealing, it can be changed with a fairly standard oven fan, but you will need access to the back of the cooker and inside the oven.
Warning. Do not attempt if you are not competent with electrical wiring. Cookers usually have a 30 Amp fuse and any mistakes could be lethal.
Was du brauchst
Disconnect the power. The cooker switch will be located near the cooker, or in a cupboard.
Remove the four screws holding the rear panel inside the oven and remove, exposing the heater element, thermostat and fan.
There are three screws holding the fan unit in place. Remove the bottom center one, and loosen the two top ones.
Carefully move the wiring out of the way, removing cable ties if necessary.
You can then lift the motor and draw it out of the top two keyhole shaped screw holes.
The spade connectors can be slid off their tabs.
Fit two of the screws to the corresponding holes in the new motor ready to insert into the keyholes.
Fit the motor into the space, hooking the two screws into their holes. Its helpful to have a second person hold the motor in place as you fit the third screw from inside the oven, and tighten up,
Reconnect the spade connectors to match the original connections.
Refit the cover using self tapping screws. If they won't bite, tie it back on using wire passed through the holes.
Fit the new fan onto the shaft inside the oven, remembering that it is a reverse thread. Then refit the rear panel inside the oven with the four screws and replace the lamp cover.
Test the oven after finishing.
