Einleitung
This guide demonstrates how to replace the bulb. This part will commonly burn out and need to be replaced, so knowing the steps to this simple repair will be very useful for a consumer.
Was du brauchst
Unscrew the two 7mm Phillips #0 screws that attach the bulb to the mainframe of the projector.
Remove the bulb housing by gently pulling on the small silver handle located on top of the bulb housing.
You may replace the entire housing unit or replace the bulb itself once you remove it from the housing unit.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
