Einleitung
This guide demonstrates how to replace the top exterior shell for the Canon LV-7210. This repair may be necessary if the projector has sustained cosmetic damage. The only tool you will need for this guide is a screwdriver.
Was du brauchst
Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
