Zum Hauptinhalt wechseln
Canon 7210 Fan Replacement
Was du brauchst
  1. Canon 7210 Fan Replacement, Exterior Shell: Schritt 1, Bild 1 von 2 Canon 7210 Fan Replacement, Exterior Shell: Schritt 1, Bild 2 von 2
    • Remove the 4 exterior 9mm Phillips #0 screws. They are located on the sides of the projector.
  2. Canon 7210 Fan Replacement: Schritt 2, Bild 1 von 3 Canon 7210 Fan Replacement: Schritt 2, Bild 2 von 3 Canon 7210 Fan Replacement: Schritt 2, Bild 3 von 3
    • Gently lift up on the shell with both hands, from the back to the front.
    • The shell will still be attached by a small cord in the front, so be careful not to tear it loose.
  3. Canon 7210 Fan Replacement, Fan: Schritt 3, Bild 1 von 1
    • Remove the two 7mm Phillips #0 screws that attach the fan to the motherboard of the projector.
  4. Canon 7210 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the fan by pulling up gently from the top.
    • Be careful to not pull too hard or quickly, since the fan is still attached to the projector with some other wires.
  5. Canon 7210 Fan Replacement: Schritt 5, Bild 1 von 1
    • Remove the 7mm Phillips #0 screw that fastens the black ground wire connected to the fan and the projector.
  6. Canon 7210 Fan Replacement: Schritt 6, Bild 1 von 1
    • Peel the sticker up on the back of the fan to expose the port where the red, white, and black wires are attached.
    • The wires will need to be cut with small wire cutters in order to completely remove the fan.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 9-3, Lacy Fall 2016 Mitglied von USF Tampa, Team 9-3, Lacy Fall 2016
USFT-LACY-F16S9G3
4 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 316
