Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
If you observe any problems inside your scanner, you will have to remove some components to do any work inside your Canon CanoScan N670U.
To reach the inner components of the scanner, you must:
  • Remove the two side bars that hold the glass scanner bed in place.
  • Remove the glass scanner bed itself.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open up your Canon CanoScan N670U to an upright position.
    • Open up your Canon CanoScan N670U to an upright position.
  2. Turn your device so that you're facing the long side of the Canon CanoScan N670U.
    • Turn your device so that you're facing the long side of the Canon CanoScan N670U.
    • Locate the small crevice between the plastic components of the scanner bed and the scanner base.
  3. Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
    • Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
    • You may cut small bits of the plastic as you're slicing the adhesive. Do not forcefully bend the plastic strip as you're cutting or it will snap.
  4. Essential Electronics Toolkit
    Kompakte Alleskönner.
    Shop Toolkits
    Essential
    Electronics
    Toolkit
    Shop Toolkits
  5. Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
    • Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
  6. Repeat steps 2-4 for the other side of the scanner.
    • Repeat steps 2-4 for the other side of the scanner.
  7. Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
    • Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
  8. Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
    • Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
  9. Slowly pull the glass scanner bed towards you and set the piece aside.
    • Slowly pull the glass scanner bed towards you and set the piece aside.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Stephen Bui
537 Reputation
4 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015
USFSM-STEWART-F15S1G1
5 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 5
Insgesamt: 624
