Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If you're having scanning issues as a result of a faulty sensor bar, this is where you will want to begin.
To replace the sensor bar in the Canon CanoScan N670U, you must:
  • Remove the two plastic bars that hold the glass scanner bed.
  • Set aside the scanner bed.
  • Loosen the belt from the plastic hook.
  • Remove the sensor bar for replacement.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open up your Canon CanoScan N670U to an upright position.
    • Open up your Canon CanoScan N670U to an upright position.
  2. Turn your device so that you're facing the long side of the Canon CanoScan N670U.
    • Turn your device so that you're facing the long side of the Canon CanoScan N670U.
    • Locate the small crevice between the plastic components of the scanner bed and the scanner base.
  3. Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
    • Carefully insert a metal spudger tool in the crevice and slowly cut through the adhesive between the plastic components.
    • You may cut small bits of the plastic as you're slicing the adhesive. Do not forcefully bend the plastic strip as you're cutting or it will snap.
  4. Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
    • Once the adhesive strip is sliced through, the plastic bar that is attached should release. Set aside the plastic bar.
  5. Repeat steps 2-4 for the other side of the scanner.
    • Repeat steps 2-4 for the other side of the scanner.
  6. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  7. Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
    • Use your hands or a metal spudger tool to push the plastic bar at the bottom of the glass scanner bed forward until you can't push it any farther.
  8. Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
    • Insert the metal spudger tool underneath the glass scanner bed. The front of the scanner bed should be resting on top of the tool.
  9. Slowly pull the glass scanner bed towards you and set the piece aside.
    • Slowly pull the glass scanner bed towards you and set the piece aside.
  10. This is the sensor bar that you will replace.
    • This is the sensor bar that you will replace.
  11. Locate the small plug where the white strip of cable is connected to. Unfurl the cable strip if it's tucked in.
    • Locate the small plug where the white strip of cable is connected to.
    • Unfurl the cable strip if it's tucked in.
  12. Gently use tweezers or your fingers to rock the cable back and forth to disconnect the it. Do not apply too much pressure or you may damage some delicate components. Do not apply too much pressure or you may damage some delicate components.
    • Gently use tweezers or your fingers to rock the cable back and forth to disconnect the it.
    • Do not apply too much pressure or you may damage some delicate components.
  13. Locate the small metal spring behind the front buttons of the Canon CanoScan N670U.
    • Locate the small metal spring behind the front buttons of the Canon CanoScan N670U.
  14. Use tweezers to gently remove the metal spring from the plastic hook. Due to the tension of the spring, it can be difficult to pull the metal end. You may attempt to use your hands to pull the spring itself if necessary.
    • Use tweezers to gently remove the metal spring from the plastic hook.
    • Due to the tension of the spring, it can be difficult to pull the metal end. You may attempt to use your hands to pull the spring itself if necessary.
    • Take caution to not bend the metal.
  15. Flip the sensor bar over and unwind the belt from the gear system. Flip the sensor bar over and unwind the belt from the gear system.
    • Flip the sensor bar over and unwind the belt from the gear system.
  16. Remove the sensor bar from the scanner and replace it with the new one.
    • Remove the sensor bar from the scanner and replace it with the new one.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Stephen Bui
537 Reputation
4 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015
USFSM-STEWART-F15S1G1
5 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 13
Insgesamt: 422
