Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
If you're having issues as a result of a dirty or faulty white document mat, this is where you will want to begin.
To remove the white document mat, you must:
  • Carefully rip out the foam that's glued onto the cover.
  • Glue in the replacement document mat.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open up the top of your Canon CanoScan N670U to this position.
    • Open up the top of your Canon CanoScan N670U to this position.
  2. The document mat is taped on to these four corners of the cover. These spots will be where we'll start removing the mat.
    • The document mat is taped on to these four corners of the cover. These spots will be where we'll start removing the mat.
  3. EINFACH ALLE TABS ÖFFNEN
    RAM Upgrade Kits für Mac
    Kits kaufen
    Genügend RAM
    für alle Tabs
    Kits kaufen
  4. Gently peel the tape on each corner of the mat using your hands or an iFixit Tech Knife.
    • Gently peel the tape on each corner of the mat using your hands or an iFixit Tech Knife.
    • Be careful to not rip the foam while peeling.
  5. Tape in your replacement document mat back onto the top cover of the scanner.
    • Tape in your replacement document mat back onto the top cover of the scanner.
Abschluss
To reassemble your device, ensure that the white document mat is firmly glued on.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Stephen Bui
537 Reputation
4 Anleitungen geschrieben
USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015 Mitglied von USF Sarasota-Manatee, Team 1-1, Stewart Fall 2015
USFSM-STEWART-F15S1G1
5 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 131
