Zum Hauptinhalt wechseln
Canon ELPH Z3 Camera Battery Replacement
  1. Canon ELPH Z3 Camera Battery  Replacement, Battery: Schritt 1, Bild 1 von 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: Schritt 1, Bild 2 von 3 Canon ELPH Z3 Camera Battery  Replacement, Battery: Schritt 1, Bild 3 von 3
    • Place the camera face down on a flat surface ( lens facing down).
    • Press firmly on the battery latch that is marked.
    • Slide the battery latch to the right to expose battery.
    • Detach the battery latch completely from the camera.
  2. Canon ELPH Z3 Camera Battery  Replacement: Schritt 2, Bild 1 von 2 Canon ELPH Z3 Camera Battery  Replacement: Schritt 2, Bild 2 von 2
    • If the battery is leaking acid. Please proceed with extreme caution. You may sustain injury!
    • Remove the battery with a piece of double sided tape if it is leaking.
    • Use a Q-tip with a small amount of rubbing alcohol to clean battery connections.
    • Remove the existing battery using your fingers.
Abschluss
UMass Dartmouth, Team 1-7, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 766
