Zum Hauptinhalt wechseln
Canon ELPH Z3 Camera Film Chamber Replacement
Was du brauchst
  1. Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: Schritt 1, Bild 1 von 3 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: Schritt 1, Bild 2 von 3 Canon ELPH Z3 Camera Film Chamber Replacement, Shutter Button: Schritt 1, Bild 3 von 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 2, Bild 1 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 2, Bild 2 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 2, Bild 3 von 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 3, Bild 1 von 2 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 3, Bild 2 von 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 4, Bild 1 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 4, Bild 2 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 4, Bild 3 von 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Film Chamber Replacement, Film: Schritt 5, Bild 1 von 2 Canon ELPH Z3 Camera Film Chamber Replacement, Film: Schritt 5, Bild 2 von 2
    • Separate the front and back coverings of the camera completely.
    • Remove both coverings from the body of the camera.
    • Flip the camera upside down and focus on the bottom right portion.
  6. Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 6, Bild 1 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 6, Bild 2 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the 4.1mm screw using a PH000 screwdriver.
    • Swivel the now loose metal portion to the right.
    • This action will open the film chamber and thus exposing the film.
  7. Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 7, Bild 1 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 7, Bild 2 von 3 Canon ELPH Z3 Camera Film Chamber Replacement: Schritt 7, Bild 3 von 3
    • Press gently on the film using your finger to slightly eject the film.
    • Pull the film from the chamber.
Abschluss
UMass Dartmouth, Team 1-7, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 909
