Zum Hauptinhalt wechseln
Canon ELPH Z3 Camera Image Sensor Replacement
Was du brauchst
  1. Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: Schritt 1, Bild 1 von 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: Schritt 1, Bild 2 von 3 Canon ELPH Z3 Camera Image Sensor Replacement, Shutter Button: Schritt 1, Bild 3 von 3
    • Unscrew the 7 4.1mm screws around the camera using a PH000 screwdriver.
  2. Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 2, Bild 1 von 3 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 2, Bild 2 von 3 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 2, Bild 3 von 3
    • Split the front and back coverings of the camera.
    • Remove the back covering completely.
    • This allows for easier access to the shutter button carrier.
  3. Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 3, Bild 1 von 2 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 3, Bild 2 von 2
    • Slide the shutter button carrier off of the camera.
    • Notice shutter button is on the right hand side of the carrier.
  4. Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 4, Bild 1 von 3 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 4, Bild 2 von 3 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 4, Bild 3 von 3
    • Press upward on the shutter button from the underside of the carrier by using your thumb.
    • Separate the shutter button from the carrier.
  5. Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: Schritt 5, Bild 1 von 2 Canon ELPH Z3 Camera Image Sensor Replacement, Rear Screen: Schritt 5, Bild 2 von 2
    • Pull apart the front and back coverings of the camera.
    • Remove the back covering completely to gain access of the rear screen.
  6. Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 6, Bild 1 von 3 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 6, Bild 2 von 3 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the 6 4.1mm screws that are holding the back screen in place by using the PH000 screwdriver.
    • This step may require for you to pull back tape to gain access to some screws.
  7. Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 7, Bild 1 von 2 Canon ELPH Z3 Camera Image Sensor Replacement: Schritt 7, Bild 2 von 2
    • Pull the yellow tape away from the side that is attached to the back screen.
    • Remove the back screen.
  8. Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: Schritt 8, Bild 1 von 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: Schritt 8, Bild 2 von 3 Canon ELPH Z3 Camera Image Sensor Replacement, Image Sensor: Schritt 8, Bild 3 von 3
    • Pull away back screen base to reveal the image sensor.
    • Remove image sensor using a set of pliers.
Abschluss
Katy Skillings
1 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 1-7, Catania Fall 2016 Mitglied von UMass Dartmouth, Team 1-7, Catania Fall 2016
UMASSD-CATANIA-F16S1G7
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 282
