Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Removing the bottom panel is safe and only requires a screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two 4.8 mm black screws above the lens on the front of the camera.
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Remove the 4.8 mm black screw on the left side of the camera.
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Remove the front panel by lifting it away from the camera's body.
    • Remove the front panel by lifting it away from the camera's body.
  5. Remove seven 4.25 mm black screws on the bottom panel.
    • Remove seven 4.25 mm black screws on the bottom panel.
  6. Remove the bottom panel.
    • Remove the bottom panel.
Abschluss
Sterling Vinson
216 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 8-8, Regan Spring 2011 Mitglied von Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Mitglieder
11 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 4
Insgesamt: 1,615
