Einleitung
Removing the front panel is the first step to accessing many internal components. Removal is safe, simple, and only requires a screwdriver.
Was du brauchst
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Eine weitere Person hat diese Anleitung absolviert.
