Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Removing the grip is necessary to reach the battery door. This process is safe and easy.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two 4.8 mm black screws above the lens on the front of the camera.
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Remove the 4.8 mm black screw on the left side of the camera.
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Remove the front panel by lifting it away from the camera's body.
    • Remove the front panel by lifting it away from the camera's body.
  5. Slide the outer eyepiece upward to remove it.
    • Slide the outer eyepiece upward to remove it.
  6. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  7. Remove the two 4.75 mm black screws located  on the top of the camera.
    • Remove the two 4.75 mm black screws located on the top of the camera.
  8. Remove the four 4.3 mm  black screws near the bottom corners of the eyepiece at the back of the camera.
    • Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
  9. Slowly separate the top panel from the camera by pushing it upward. Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
    • Slowly separate the top panel from the camera by pushing it upward.
    • Separating the top panel too far or quickly can damage the ribbon cable and connecting wires that are still attached to the top panel of the camera.
  10. Remove two 6.5 mm black screws from the panel.
    • Remove two 6.5 mm black screws from the panel.
  11. Remove the plastic remote control socket cap by pulling it straight out.
    • Remove the plastic remote control socket cap by pulling it straight out.
  12. Slide panel toward bottom of camera to remove. Slide panel toward bottom of camera to remove.
    • Slide panel toward bottom of camera to remove.
  13. Remove the two 5.5 mm screws from front of camera.
    • Remove the two 5.5 mm screws from front of camera.
  14. Remove grip panel.
    • Remove grip panel.
Abschluss
Jackie
218 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 8-8, Regan Spring 2011 Mitglied von Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Mitglieder
22 Anleitungen geschrieben
Didn't you forget the step to remove the bottom plate?
Sino Lino - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 6
Insgesamt: 3,113
