Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
The three stacked rings in the lens mount ring can be safely and easily removed.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the two 4.8 mm black screws above the lens on the front of the camera.
    • Remove the two 4.8 mm black screws above the lens on the front of the camera.
  2. Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
    • Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
  3. Remove the 4.8 mm black screw on the left side of the camera.
    • Remove the 4.8 mm black screw on the left side of the camera.
  4. Remove the front panel by lifting it away from the camera's body.
    • Remove the front panel by lifting it away from the camera's body.
  5. Remove four 7.1 mm silver screws from lens mount ring.
    • Remove four 7.1 mm silver screws from lens mount ring.
  6. Remove outer mount ring.
    • Remove outer mount ring.
    • The silver button may detach.
  7. Remove thin gold ring.
    • Remove thin gold ring.
    • Correct orientation is pictured.
  8. Remove thin silver ring.
    • Remove thin silver ring.
  9. All rings are removed.
    • All rings are removed.
    • Follow pictures in reverse order to replace rings.
Abschluss
Antonia
109 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 8-8, Regan Spring 2011 Mitglied von Cal Poly, Team 8-8, Regan Spring 2011
CPSU-REGAN-S11S8G8
5 Mitglieder
11 Anleitungen geschrieben
Very handy. One addition though - the silver button lever is on the wrong side - it is not facing the mirror box but the plastic lens release button. Plus, you are missing the fact that there is a spring underneatch the silver leaver which keeps the mount pin coming back up.
Patryk Granatowicz - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 10
Letzten 30 Tage: 41
Insgesamt: 4,406
