Einleitung
The top panel can be safely separated from the camera body, but it will remain attached by several wires and a ribbon cable. Separating the top panel allows access to several important components.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Remove the two 4.8 mm black screws above the lens on the front of the camera.
Remove the 4.3 mm black screw under the lens ring, and the 4.8 mm black screw under the camera.
Remove the four 4.3 mm black screws near the bottom corners of the eyepiece at the back of the camera.
Ein weiterer Nutzer hat diese Anleitung absolviert.
