Einleitung
Removing the side with the grip allows for replacements on the battery door, as well as access to the top panel.
Werkzeuge
Ersatzteile
Kein Ersatzteil erforderlich.
Using your finger, carefully pry open the side panel from the top of camera.
Pull panel downwards to remove.
Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
Remove five black 4.8mm Phillips #1 screws.
Simply remove the bottom panel by prying it off with your finger.
Be wary of a loose piece of foam attached to the bottom panel.
