Einleitung
This guide will show users how to remove the front panel. It is necessary to remove the front panel in order to remove the top panel and access many internal components.
Was du brauchst
Peel back the rubber cover above the in/out ports to reveal two screw heads.
Lift the in/out port plastic covering from the bottom where the backup battery used to be.
Remove each 6.3 mm screw on either side of the viewfinder using a Phillips #0 screwdriver.
Remove the three 4.8 mm screws on the bottom of the back plate using a Phillips #0.
Peel back the rubber covering next to the menu dial to access the screw.
Remove the single 3.4 mm screw using a Phillips #0.
The back panel can now fall off easily by turning the device upside down. Be sure to catch it so the data ribbons do not tear or tug.
Remove each data ribbon cable from the motherboard by applying pressure down towards the motherboard and gently sliding your thumb upwards on the slot where the cable meets the motherboard. This will raise a very small clip that locks the cable in place.
The back panel is now free from the rest of the device.
Peel off the rubber cover on the front panel in order to access the screws underneath.
Remove the two 4.8 mm screws above where the lens would be using a Phillips #0.
Remove the single screw underneath where the lens would be using a Phillips #0.
Remove the four 3.0 mm screws next to the memory card reader using a Phillips #0.
Remove the front panel by lifting upwards from the right side where the in/out ports used to be.
12 weitere Personen haben diese Anleitung absolviert.
