Zum Hauptinhalt wechseln
Canon EOS 70D Camera Motherboard Replacement
Was du brauchst
  1. Canon EOS 70D Camera Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
    • Pull cover over to expose the battery.
  2. Canon EOS 70D Camera Motherboard Replacement: Schritt 2, Bild 1 von 2 Canon EOS 70D Camera Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Press the white button with your finger to release the battery.
    • Once released, the battery will eject out about two inches
  3. Canon EOS 70D Camera Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Pull battery out of the camera.
  4. Canon EOS 70D Camera Motherboard Replacement, LCD Touchscreen: Schritt 4, Bild 1 von 2 Canon EOS 70D Camera Motherboard Replacement, LCD Touchscreen: Schritt 4, Bild 2 von 2
    • Pull Touchscreen out and rotate 90 degrees. Remove the four 3 mm Phillips #000 head screws that are now exposed at the hinge.
    • Remove the two 5 mm Phillips #000 head screws that near the viewfinder.
    • Use a spudger and pry apart the two plastic columns surrounding the screen hinge.
    • The screen will not be removed at this step.
    • Rotate the screen forward 90 degrees and push it back into its housing against the camera.
  5. Canon EOS 70D Camera Motherboard Replacement: Schritt 5, Bild 1 von 2 Canon EOS 70D Camera Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Use a spudger to peel rubber matting on left hand side to expose camera backplate mounting screws.
    • Remove three 4 mm Phillip #000 head screws that mount the backplate to the left side of camera.
  6. Canon EOS 70D Camera Motherboard Replacement: Schritt 6, Bild 1 von 2 Canon EOS 70D Camera Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Use tweezers to pry rubber matting on right hand side to expose backplate mounting screws.
    • Remove four 4 mm Phillips #000 head screws that mount the backplate to the right side of camera.
  7. Canon EOS 70D Camera Motherboard Replacement: Schritt 7, Bild 1 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 7, Bild 2 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 7, Bild 3 von 3
    • Turn camera upside down. Remove five 5 mm Phillips #000 head screws securing the backplate to the bottom of the camera.
    • Grab the backplate and gently pull away from camera.
    • The backplate will still be attached by the wires running to the LCD touchscreen.
    • The screen will still be attached to the camera and won't be removed until step 10.
  8. Canon EOS 70D Camera Motherboard Replacement: Schritt 8, Bild 1 von 2 Canon EOS 70D Camera Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Carefully pry open backplate from camera to expose LCD connector (white wire). LCD connector is attached with a metal bar to the motherboard.
    • Use tweezers to gently pry metal bar connector from camera motherboard.
  9. Canon EOS 70D Camera Motherboard Replacement: Schritt 9, Bild 1 von 2 Canon EOS 70D Camera Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Remove two 4 mm Phillips #000 head screws that mount the LCD touchscreen to the hinge on the camera.
  10. Canon EOS 70D Camera Motherboard Replacement: Schritt 10, Bild 1 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 10, Bild 2 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 10, Bild 3 von 3
    • Grip the screen with your hand and gently pull white connecting wire through hole in backplate.
    • Once the connector reaches the hole, twist the connector and pull completely through hole.
    • You must twist the connector in order to fit through hole.
  11. Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: Schritt 11, Bild 1 von 3 Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: Schritt 11, Bild 2 von 3 Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: Schritt 11, Bild 3 von 3
    • Use spudger to lift edge of black heat tape.
    • Slowly peel back black heat tape.
  12. Canon EOS 70D Camera Motherboard Replacement: Schritt 12, Bild 1 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 12, Bild 2 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 12, Bild 3 von 3
    • Very carefully, use spudger to remove nine orangish ribbon cables.
    • Using tweezers remove the two wire cables shown.
    • Slowly remove ribbon cables because they can tear very easily.
  13. Canon EOS 70D Camera Motherboard Replacement: Schritt 13, Bild 1 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 13, Bild 2 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 13, Bild 3 von 3
    • Remove seven 5 mm Phillips #000 head screws around motherboard.
    • Once the five screws are removed, remove the metal chip covered by hand.
    • This will leave the mother board exposed, attached by two cable wires underneath.
  14. Canon EOS 70D Camera Motherboard Replacement: Schritt 14, Bild 1 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 14, Bild 2 von 3 Canon EOS 70D Camera Motherboard Replacement: Schritt 14, Bild 3 von 3
    • Slowly lift motherboard to expose the two cable wires underneath.
    • Using tweezers, unattach the two wire cables holding the motherboard in.
  15. Canon EOS 70D Camera Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Carefully remove motherboard.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Baker
343 Reputation
1 Anleitung geschrieben
3 Kommentare
Great write up and illustrations. I'm in the process of repairing a 70D and this will be a great help.
Thank you and keep up the good work!
marcuscleveland85 - Antwort
Hi, do you know if after replacing the main board it is necessary to configure the camera with some software ? (I heard of spt software)
Stephen Lay -
Hi Tyler my Canon Camera eos 70D isn’t working anymore is it possible to replace the motherboard?
Charlie Laguna - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 220
Insgesamt: 14,481
