Zum Hauptinhalt wechseln
Canon EOS 70D EFS 18-135mm Lens Main Board Replacement
Was du brauchst
  1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: Schritt 1, Bild 1 von 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: Schritt 1, Bild 2 von 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: Schritt 1, Bild 3 von 3
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 2, Bild 1 von 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 2, Bild 2 von 2
    • Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
    • Remove the two 4-mm Phillips #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 3, Bild 1 von 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 3, Bild 2 von 2
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 4, Bild 1 von 2 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 4, Bild 2 von 2
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 5, Bild 1 von 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 5, Bild 2 von 3 Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 4-mm Phillips #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Paul
789 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 36
Insgesamt: 2,191
