Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Removing the front cover gives access to lens housing, and allows removal of the top cover.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  2. Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  3. Remove the battery from inside the battery housing and set the cover aside.
    • Remove the battery from inside the battery housing and set the cover aside.
  4. Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
    • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Remove the 6.4mm screw from the inside of the flash bezel.
    • Remove the 6.4mm screw from the inside of the flash bezel.
    • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
  7. Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
    • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
  8. Remove the 5.6mm screws behind the battery cover.
    • Remove the 5.6mm screws behind the battery cover.
  9. Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
    • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
  10. Remove the 6.4mm screw on the top of the inside edge of the battery hole.
    • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
  11. Starting at the flash, carefully pull the front cover away from the camera. Starting at the flash, carefully pull the front cover away from the camera.
    • Starting at the flash, carefully pull the front cover away from the camera.
Abschluss
Mark
119 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 8-9, Regan Spring 2011 Mitglied von Cal Poly, Team 8-9, Regan Spring 2011
CPSU-REGAN-S11S8G9
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 4
Letzten 30 Tage: 9
Insgesamt: 2,167
