Einleitung
Removing the top cover of camera gives access to the LCD screen, control dial, and flash.
Was du brauchst
Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
Once you have revealed the ribbon cable, gently let the top cover hang off the front of the camera. Use the plastic opening tool to gently pull the white tabs on the ribbon cable, releasing the ribbon cable.
Eine weitere Person hat diese Anleitung absolviert.
