Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide teaches how to to install the back panel latch on your camera.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Two 4.3 mm Phillips screws
  5. Open the back panel by pushing the locking latch up.
    • Open the back panel by pushing the locking latch up.
    • Lift the latch cover off of the camera body.
  6. Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Sometimes the latch will detach while pushing it up.
Abschluss
Zach
43 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Spring 2012 Mitglied von Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Mitglieder
24 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 9
Insgesamt: 2,022
