Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will instruct you how to install the flash on your camera.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Pop the flash up with your thumb Pop the flash up with your thumb
    • Pop the flash up with your thumb
  5. Unscrew the two screws on the front of the flash near the bulb cover.
    • Unscrew the two screws on the front of the flash near the bulb cover.
  6. Close the flash. Lift the flash cover off. Lift the flash cover off.
    • Close the flash.
    • Lift the flash cover off.
  7. Pull off yellow capacitor from flash wiring. Pull off yellow capacitor from flash wiring.
    • Pull off yellow capacitor from flash wiring.
  8. Remove white cocking with a razor blade, and then unsolder connection.
    • Remove white cocking with a razor blade, and then unsolder connection.
  9. Remove the flash cover to access the flash bulb. After wires are unsoldered, slide flash bulb out from housing.
    • Remove the flash cover to access the flash bulb.
    • After wires are unsoldered, slide flash bulb out from housing.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Zach
43 Reputation
8 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Spring 2012 Mitglied von Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Mitglieder
24 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 1
Insgesamt: 1,881
