Einleitung
This guide will instruct you how to install the flash on your camera.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using your finger, peel back the textured grip so the components are separated.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Remove the flash cover to access the flash bulb.
After wires are unsoldered, slide flash bulb out from housing.
