Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide shows you how to install the front panel of your camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kyle Reis
52 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Spring 2012 Mitglied von Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Mitglieder
24 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 728
