Einleitung
This guide shows you how to install the front panel of your camera.
Was du brauchst
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using your finger, peel back the textured grip so the components are separated.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
