Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide shows you how to install the grip on your camera.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Using your finger, peel back the textured grip so the components are separated. Using your finger, peel back the textured grip so the components are separated.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Using the flat end of a spudger, loosen the connection between the front panel and the device. Remove the front panel using your hands. Remove the front panel using your hands.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
    • Using a 00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws. on the inside of the camera.
  5. Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Using a 00 Phillips screw driver, unscrew the two 4.3 mm Phillips screws on the side of the camera.
    • Use your fingers to pull out the plug that is located between the screw holes.
  6. Use the flat end of a spudger to pop the grip off and remove grip. Use the flat end of a spudger to pop the grip off and remove grip.
    • Use the flat end of a spudger to pop the grip off and remove grip.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Kyle Reis
52 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Spring 2012 Mitglied von Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Mitglieder
24 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 8
Insgesamt: 1,310
