Einleitung
This guide shows you how to install a new lens connector.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Using your finger, peel back the textured grip so the components are separated.
Using the flat end of a spudger, loosen the connection between the front panel and the device.
Remove the front panel using your hands.
Using a Phillips #00 screwdriver, remove the 5 indicated screws
Five 6.2 mm Phillips screws
2 weitere Nutzer haben diese Anleitung absolviert.
