Zum Hauptinhalt wechseln
Canon EOS Rebel G Viewfinder Replacement
Was du brauchst
  1. Canon EOS Rebel G Viewfinder Replacement, Front Panel: Schritt 1, Bild 1 von 1
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Viewfinder Replacement: Schritt 2, Bild 1 von 2 Canon EOS Rebel G Viewfinder Replacement: Schritt 2, Bild 2 von 2
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Viewfinder Replacement: Schritt 3, Bild 1 von 3 Canon EOS Rebel G Viewfinder Replacement: Schritt 3, Bild 2 von 3 Canon EOS Rebel G Viewfinder Replacement: Schritt 3, Bild 3 von 3
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Viewfinder Replacement, Top Panel: Schritt 4, Bild 1 von 1
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Viewfinder Replacement: Schritt 5, Bild 1 von 1
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Viewfinder Replacement: Schritt 6, Bild 1 von 1
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Viewfinder Replacement: Schritt 7, Bild 1 von 3 Canon EOS Rebel G Viewfinder Replacement: Schritt 7, Bild 2 von 3 Canon EOS Rebel G Viewfinder Replacement: Schritt 7, Bild 3 von 3
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Viewfinder Replacement, Viewfinder: Schritt 8, Bild 1 von 1
    • Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
    • Two 8.5 mm Phillips screws
Abschluss
Kyle Reis
52 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 14-9, Forte Spring 2012 Mitglied von Cal Poly, Team 14-9, Forte Spring 2012
CPSU-FORTE-S12S14G9
5 Mitglieder
36 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 2,934
