Einleitung
This guide will provide you with intructions to take out the existing broken eyepiece and replace with a new one.
Was du brauchst
If necessary, remove the rubber grip around the eyepiece by gently peeling it off.
Use your index finger and thumb to grip the eyepiece by the sides.
Pinch your fingers together and wiggle the eye piece gently upwards until it is detached from the camera.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
