Was du brauchst
Turn off camera using the power button on the top of the camera.
On the bottom of the camera, open the battery door and remove the battery.
Remove 1 screw from the left side of the camera.
Inside the rubber door, remove the two silver screws.
Remove the two black screws on the front of the camera just above the lens mounting ring.
NOTE: Do not remove any of the silver screws on the lens mount ring. This could cause problems with auto focussing features.
Using the spudger and plastic opening tool, pry the bottom of the front panel of the camera over the tripod mount.
The screws holding the tripod mount are now exposed.
Remove the screws securing the tripod mount
With the screws removed, the tripod mount can now be easily pulled free.
