Einleitung
Use this guide to replace the front casing on your Canon EOS Rebel T3i.
Was du brauchst
Hook your finger onto the compartment door latch.
Open the battery compartment door.
Remove the three 3 mm Phillips #000 screws.
Remove the single 6 mm Phillips #000 screw.
After separating the back, gently lift off one side of the light blue wire with the spudger until the connector is totally removed.
With the spudger, remove the orange ribbon cable leading to the circuit board from the back of the camera.
6 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
when I connect and lens the camera replies that the lens is properly connected. One of the copper lens connectors on the camera’s body is kinda greenish rather than gold, so I wanna clean it, how to do that?
