Zum Hauptinhalt wechseln
Canon EOS Rebel T5 Back Cover Removal
Was du brauchst
  1. Canon EOS Rebel T5 Back Cover Removal, Battery: Schritt 1, Bild 1 von 1
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Back Cover Removal: Schritt 2, Bild 1 von 1
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Back Cover Removal, Back Cover: Schritt 3, Bild 1 von 1
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Back Cover Removal: Schritt 4, Bild 1 von 1
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Back Cover Removal: Schritt 5, Bild 1 von 1
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm JIS #000 screws.
  6. Canon EOS Rebel T5 Back Cover Removal: Schritt 6, Bild 1 von 1
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
  7. Canon EOS Rebel T5 Back Cover Removal: Schritt 7, Bild 1 von 3 Canon EOS Rebel T5 Back Cover Removal: Schritt 7, Bild 2 von 3 Canon EOS Rebel T5 Back Cover Removal: Schritt 7, Bild 3 von 3
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Johnyp
266 Reputation
1 Anleitung geschrieben
USF Tampa, Team 16-4, Wollert Fall 2015 Mitglied von USF Tampa, Team 16-4, Wollert Fall 2015
USFT-WOLLERT-F15S16G4
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 20
Letzte 30 Tage: 25
Insgesamt: 3,650
