Zum Hauptinhalt wechseln
Canon EOS Rebel T6i Motherboard Replacement
Was du brauchst
  1. Canon EOS Rebel T6i Motherboard Replacement, Flash Assembly: Schritt 1, Bild 1 von 3 Canon EOS Rebel T6i Motherboard Replacement, Flash Assembly: Schritt 1, Bild 2 von 3 Canon EOS Rebel T6i Motherboard Replacement, Flash Assembly: Schritt 1, Bild 3 von 3
    • Remove two 6.8 mm JIS #000 screws on the right side.
    • Remove six 5.3 mm JIS #000 screws on the bottom.
    • Remove two 5.3 mm JIS #000 screws on either side of the viewfinder.
  2. Canon EOS Rebel T6i Motherboard Replacement: Schritt 2, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Remove one 5.9 mm JIS #000 screw on the top right.
    • Remove one 3.4 mm JIS #000 screw on the top left.
  3. Canon EOS Rebel T6i Motherboard Replacement: Schritt 3, Bild 1 von 3 Canon EOS Rebel T6i Motherboard Replacement: Schritt 3, Bild 2 von 3 Canon EOS Rebel T6i Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Using a metal spudger, pry the rubber grip off of the casing on the left side of the camera.
    • Potential for device damage: Be careful not to rip the rubber with the metal spudger.
    • Remove five silver 5.8 mm JIS #000 screws from underneath the grip.
  4. Canon EOS Rebel T6i Motherboard Replacement: Schritt 4, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using the metal spudger, pry the rubber grip located just below the turndial.
    • Potential for device damage: Be careful not to rip the rubber.
  5. Canon EOS Rebel T6i Motherboard Replacement: Schritt 5, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Carefully use the plastic opening tool to pry the casing apart along the seam.
    • Follow the seam with the plastic tool until the back is ready to remove.
    • Potential for device damage: Make sure you use the grounding strip to remove the chance of discharging static electricity into the internal components.
  6. Canon EOS Rebel T6i Motherboard Replacement: Schritt 6, Bild 1 von 3 Canon EOS Rebel T6i Motherboard Replacement: Schritt 6, Bild 2 von 3 Canon EOS Rebel T6i Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Notice the two connections attaching the back of the camera to the motherboard.
    • To disconnect the white wire, pinch the wire casing and pull it directly out from the camera.
    • This may take a very small amount of strength; however, do not force or pry it.
    • To disconnect the ribbon connector, softly pull the back away from the motherboard. It should come undone with little force.
    • Once removed, set the back in a safe place.
  7. Canon EOS Rebel T6i Motherboard Replacement: Schritt 7, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove the five ribbon connectors along the bottom of the assembly using either needle nose tweezers or a plastic opening tool to flip the small flaps to the "up" position.
    • Use a nylon spudger to pull each ribbon connector out of its connection using the hole in the center of the ribbon.
  8. Canon EOS Rebel T6i Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the button cell battery from the motherboard using a pair of tweezers.
  9. Canon EOS Rebel T6i Motherboard Replacement: Schritt 9, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Disconnect the small plastic connectors on the top left corner of the motherboard by gripping the small plastic portion of the wire and gently pulling out of the connector.
    • Disconnect the three ribbon connectors along the top.
    • Don't detach the connectors underneath or the ribbon connectors with the foam block, as these will be removed later.
  10. Canon EOS Rebel T6i Motherboard Replacement: Schritt 10, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the four screws from the front of the camera. There are two screws above the lens mount and two screws inside the lens mount.
    • Remove the four screws from the bottom of the camera.
  11. Canon EOS Rebel T6i Motherboard Replacement: Schritt 11, Bild 1 von 3 Canon EOS Rebel T6i Motherboard Replacement: Schritt 11, Bild 2 von 3 Canon EOS Rebel T6i Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Using the plastic opening tool, pry the front of the casing off of the camera.
    • Warning: Electric Shock! Be careful not to touch the terminals of the capacitor (black cylinder). This can cause the capacitor to discharge.
  12. Canon EOS Rebel T6i Motherboard Replacement: Schritt 12, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 12, Bild 2 von 2
    • Remove the yellow and red connections on the front near the black cylinder (capacitor).
    • The yellow connector will just pop out if pried from the bottom using a plastic opening tool.
    • The red connector will pull out of the casing with either a plastic opening tool or a thin set of tweezers.
  13. Canon EOS Rebel T6i Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the diopter adjustment knob next to the viewfinder using a JIS #000 screwdriver.
  14. Canon EOS Rebel T6i Motherboard Replacement: Schritt 14, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Remove the entire upper flash assembly by gently pulling it up and off the camera.
    • The flash assembly is sold as a single piece.
  15. Canon EOS Rebel T6i Motherboard Replacement, Motherboard: Schritt 15, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement, Motherboard: Schritt 15, Bild 2 von 2
    • Disconnect the ribbon connector on the upper right side of the motherboard.
    • Pull back the foam on the connector on the far right side of the motherboard.
    • Flip up the tab on the connector and remove the cable.
  16. Canon EOS Rebel T6i Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Remove the two screws on the right side of the motherboard as well as the screw in the center.
  17. Canon EOS Rebel T6i Motherboard Replacement: Schritt 17, Bild 1 von 2 Canon EOS Rebel T6i Motherboard Replacement: Schritt 17, Bild 2 von 2
    • Remove the two screws connecting the metal port bracket to the motherboard.
    • Slide the metal bracket out of the camera.
  18. Canon EOS Rebel T6i Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Remove the motherboard from the device.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
Shane Riding
861 Reputation
4 Anleitungen geschrieben
2 Kommentare
To change the CMOS sensor, How do it??
ivanram - Antwort
Good tutorial! Two things I noticed on my teardown, on step 6 the white grounding wire has two black tabs on either side you can lift with a guitar pick, much better than pulling on the wire casing; on step 12 the picture is misleading as you pull the plug out towards the middle of the body. Those are very minor things, this was an extremely helpful tutorial! Not for the faint of heart aha
Tom - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 16
Letzte 30 Tage: 62
Insgesamt: 4,275
