Zum Hauptinhalt wechseln
Canon EOS Rebel XS 35mm Bottom Cover Replacement
Was du brauchst
  1. Canon EOS Rebel XS 35mm Bottom Cover Replacement, Bottom Cover: Schritt 1, Bild 1 von 1
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover Replacement: Schritt 2, Bild 1 von 1
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
Abschluss
christiansvezia
1.108 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 200
