Zum Hauptinhalt wechseln
Canon EOS Rebel XS 35mm Flash Replacement
Was du brauchst
  1. Canon EOS Rebel XS 35mm Flash Replacement, Flash: Schritt 1, Bild 1 von 2 Canon EOS Rebel XS 35mm Flash Replacement, Flash: Schritt 1, Bild 2 von 2
    • Pull up on the flash / the camera part housing the flash, as shown in the pictures. If this isn't working, try these things not shown in the pictures: 1) using a spudger, your nail, or the like to pry it open; or 2) pull it open with your finger and thumb on either side of it.
  2. Canon EOS Rebel XS 35mm Flash Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Phillips #000 Screwdriver
    $5.49
    Kaufen
    • Using a PH000 screwdriver bit, remove the two silver screws circled in the picture. Both screws are 5 mm in length and about 1.25 mm in diameter.
Abschluss
christiansvezia
1.108 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 509
