Zum Hauptinhalt wechseln
Canon EOS Rebel XS 35mm Top Cover Replacement
Was du brauchst
  1. Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: Schritt 1, Bild 1 von 2 Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: Schritt 1, Bild 2 von 2
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Top Cover Replacement: Schritt 2, Bild 1 von 1
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Top Cover Replacement: Schritt 3, Bild 1 von 1
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Top Cover Replacement: Schritt 4, Bild 1 von 3 Canon EOS Rebel XS 35mm Top Cover Replacement: Schritt 4, Bild 2 von 3 Canon EOS Rebel XS 35mm Top Cover Replacement: Schritt 4, Bild 3 von 3
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
christiansvezia
1.108 Reputation
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 308
