Zum Hauptinhalt wechseln
Canon EOS Rebel XS LCD Replacement
Was du brauchst
  1. Canon EOS Rebel XS LCD Replacement, Latch Side Cover: Schritt 1, Bild 1 von 1
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. Canon EOS Rebel XS LCD Replacement: Schritt 2, Bild 1 von 1
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. Canon EOS Rebel XS LCD Replacement, Back Cover: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  4. Canon EOS Rebel XS LCD Replacement: Schritt 4, Bild 1 von 1
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  5. Canon EOS Rebel XS LCD Replacement, LCD: Schritt 5, Bild 1 von 1
    • Use the tweezers to gently remove the straps (in the teal box).
    • Use the Phillips Screwdriver to remove the four screws (in the red dots).
    • Use your fingers to remove the silver plate.
  6. Canon EOS Rebel XS LCD Replacement: Schritt 6, Bild 1 von 1
    • Use the Spudger on the edges of the screen.
    • Once one end is lose, use the tweezers to lift the screen.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Daniel Bussone
1.260 Reputation
11 Anleitungen geschrieben
Cal Poly, Team 3-41, Regan Winter 2011 Mitglied von Cal Poly, Team 3-41, Regan Winter 2011
CPSU-REGAN-W11S3G41
2 Mitglieder
21 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 7,369
