Zum Hauptinhalt wechseln
Canon EOS Rebel XSi LCD Screen Replacement
Was du brauchst
  1. Canon EOS Rebel XSi LCD Screen Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi LCD Screen Replacement, LCD Screen: Schritt 9, Bild 1 von 1
    • Using the PH00 screwdriver head, unscrew four 4 mm screws and one 2 mm screw
  10. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 10, Bild 1 von 2 Canon EOS Rebel XSi LCD Screen Replacement: Schritt 10, Bild 2 von 2
    • Remove the metal plate covering inside of the LCD screen
  11. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Carefully disconnect the circuitry sheets from the white plastic bases
  12. Canon EOS Rebel XSi LCD Screen Replacement: Schritt 12, Bild 1 von 2 Canon EOS Rebel XSi LCD Screen Replacement: Schritt 12, Bild 2 von 2
    • Using the plastic spudger, carefully pry out the LCD screen from the back panel
Abschluss
Erik Mork
596 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 22-10, Maness Winter 2017 Mitglied von Cal Poly, Team 22-10, Maness Winter 2017
CPSU-MANESS-W17S22G10
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 1,717
