Einleitung
Prerequisite Only
Removing the front portion of the casing is necessary to perform maintenance or replace parts on specific components on the front of the camera. In order to remove the front casing, the back will have to be removed first.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Place the camera upside down, and position it to where the back of the camera is visible.
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Pull the orange tab to the right to release the primary battery.
    • Pull the orange tab to the right to release the primary battery.
  3. To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Slide the memory card door in the direction of the arrow engraved on the camera.
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  7. With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  8. Remove the three black 4 mm JIS #0 screws on the bottom of the camera.
    • Remove the three black 4 mm JIS #0 screws on the bottom of the camera.
  9. Remove the two black 6 mm Phillips screws from the right side of the camera. Remove the two black 6 mm Phillips screws from the right side of the camera.
    • Remove the two black 6 mm Phillips screws from the right side of the camera.
  10. Remove the two black 4 mm Phillips screws on each side of the camera under the strap hooks. Remove the two black 4 mm Phillips screws on each side of the camera under the strap hooks. Remove the two black 4 mm Phillips screws on each side of the camera under the strap hooks.
    • Remove the two black 4 mm Phillips screws on each side of the camera under the strap hooks.
  11. Remove the two black 4 mm Phillips head screws on the side of the camera opposite to the hand grip.
    • Remove the two black 4 mm Phillips head screws on the side of the camera opposite to the hand grip.
  12. Remove the three 1 mm Phillips #0 screws located in the memory card slot.
    • Remove the three 1 mm Phillips #0 screws located in the memory card slot.
    • Two of these screws are black, and the third is silver.
  13. Gently pry off the back casing.
    • Gently pry off the back casing.
    • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
    • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
    • Gently pull the ribbon cable out of the connector.
  14. Remove the single silver 3 mm Phillips screw.
    • Remove the single silver 3 mm Phillips screw.
  15. Remove the single 6 mm Phillips screw.
    • Remove the single 6 mm Phillips screw.
    • Remove the single 4 mm Phillips screw.
    • Remove the single 3 mm Phillips screw on the bottom of the lens.
  16. Gently pry off the front casing.
    • Gently pry off the front casing.
    • There are no ribbon cables to remove for this portion of the disassembly.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nicholas Abate
629 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 8-6, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Mitglieder
9 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 636
