Zum Hauptinhalt wechseln
Canon EOS Rebel XTi Snapshot Button Replacement
Was du brauchst
  1. Canon EOS Rebel XTi Snapshot Button Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 2, Bild 1 von 1
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 3, Bild 1 von 1
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Snapshot Button Replacement, Memory Card: Schritt 4, Bild 1 von 1
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 5, Bild 1 von 1
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 6, Bild 1 von 1
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: Schritt 7, Bild 1 von 3 Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: Schritt 7, Bild 2 von 3 Canon EOS Rebel XTi Snapshot Button Replacement, Top Casing: Schritt 7, Bild 3 von 3
    • Remove the single 10 mm JIS #00 shoulder screw.
    • Remove the two 6 mm JIS #00 screws.
  8. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 8, Bild 1 von 1
    • Separate the top casing from the electrical components enough to expose the wire harnesses that will need to be disconnected.
    • Ensure to remove the casing gently. There are several wire harnesses connecting the motherboard to components on the casing.
  9. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 9, Bild 1 von 1
    • Unplug the yellow connector located on the top of the camera.
  10. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 10, Bild 1 von 1
    • Disconnect the red connector located by the USB port.
  11. Canon EOS Rebel XTi Snapshot Button Replacement, Snapshot Button: Schritt 11, Bild 1 von 1
    • Use a J00 screwdriver to remove the two silver 4 mm screws from underneath the snapshot button.
  12. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 12, Bild 1 von 3 Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 12, Bild 2 von 3 Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 12, Bild 3 von 3
    • Use a J00 screwdriver to remove the 3 mm screws from the plate under snapshot the snapshot button.
    • Place the components off to the side without removing any ribbons.
    • Be careful as ribbon cables are fragile and may rip easily.
  13. Canon EOS Rebel XTi Snapshot Button Replacement: Schritt 13, Bild 1 von 1
    • Use a 1.5 flat head bit to remove the c-clip from underneath the snapshot button by pushing against the open side of the pin.
Abschluss
Luis Calle
416 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 8-6, Eyestone Fall 2015 Mitglied von USF Tampa, Team 8-6, Eyestone Fall 2015
USFT-EYESTONE-F15S8G6
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,074
