Einleitung
If you find that your scanner light does not seem to be moving, then your scanner belt could be the problem. Your scanner belt could be damaged or worn. This guide will help you to replace your scanner belt.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. If at any point you see glass that seems cracked or broken, handle with care.  Broken glass is sharp and can cause serious damage.
    • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
    • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
  2. Locate the black and white hinges. Gently lift out the black and white hinges. Gently lift out the black and white hinges.
    • Locate the black and white hinges.
    • Gently lift out the black and white hinges.
  3. Next, locate and remove the four 10mm screws. Next, locate and remove the four 10mm screws. Next, locate and remove the four 10mm screws.
    • Next, locate and remove the four 10mm screws.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Gently, pry off the top plate, starting from the back of the printer.
    • Gently, pry off the top plate, starting from the back of the printer.
  6. After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury. After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
    • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
  7. Remove the black component by gently pulling it up from the black scanner belt Remove the black component by gently pulling it up from the black scanner belt
    • Remove the black component by gently pulling it up from the black scanner belt
  8. Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track. Take a new belt and put it in the same way that you took it out.
    • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
    • Take a new belt and put it in the same way that you took it out.
Abschluss
Tanner Papenfuss
503 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-1, Forte Fall 2013 Mitglied von Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Mitglieder
8 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 25
Insgesamt: 1,950
