Zum Hauptinhalt wechseln
Canon ImageCLASS MF4350d Speaker Replacement
Was du brauchst
  1. Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Front Paneling: Schritt 1, Bild 1 von 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Speaker Replacement: Schritt 2, Bild 1 von 2 Canon ImageCLASS MF4350d Speaker Replacement: Schritt 2, Bild 2 von 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Speaker Replacement: Schritt 3, Bild 1 von 2 Canon ImageCLASS MF4350d Speaker Replacement: Schritt 3, Bild 2 von 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: Schritt 4, Bild 1 von 3 Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: Schritt 4, Bild 2 von 3 Canon ImageCLASS MF4350d Speaker Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: Schritt 4, Bild 3 von 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Lay printer on its left side for better access to the speaker.
    • Note: The scanner lid needs to be supported when moving the printer
  6. Canon ImageCLASS MF4350d Speaker Replacement: Schritt 6, Bild 1 von 2 Canon ImageCLASS MF4350d Speaker Replacement: Schritt 6, Bild 2 von 2
    • Locate the black 7mm screw holding the speaker in place.
    • Using a Phillips head screw driver, unscrew the 7mm screw.
  7. Canon ImageCLASS MF4350d Speaker Replacement: Schritt 7, Bild 1 von 3 Canon ImageCLASS MF4350d Speaker Replacement: Schritt 7, Bild 2 von 3 Canon ImageCLASS MF4350d Speaker Replacement: Schritt 7, Bild 3 von 3
    • Locate the red and black wires connected to the speaker.
    • Undo the white clip holding the wires in place by pinching the tab on the top.
    • Remove the red and black wires from the wire bundle.
    • When replacing the old speaker, do not touch any part of the new speaker that is not metal other than the wires. Doing so could damage the speaker.
    • Lift out the speaker
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Helena Yanez
455 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-1, Forte Fall 2013 Mitglied von Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 1,352
