Einleitung
This guide will teach you how to replace your printer's right side transformer. Do not touch anything other than what is specified, specifically on the green board. You may accidentally short or damage the electrical configurations or give yourself an electric shock.
Was du brauchst
Lift the printer lid up as shown in the photo.
Unhook the plastic panel from the printer starting from the top.
To remove the bottom part of the paneling gently lay the printer on its back.
Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
Locate the yellow wire connected to the metal box.
Carefully pull the yellow wire from the black connector.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
