Zum Hauptinhalt wechseln
Canon ImageCLASS MF4350d Transformer Replacement
Was du brauchst
  1. Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Front Paneling: Schritt 1, Bild 1 von 1
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Transformer Replacement: Schritt 2, Bild 1 von 2 Canon ImageCLASS MF4350d Transformer Replacement: Schritt 2, Bild 2 von 2
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Transformer Replacement: Schritt 3, Bild 1 von 2 Canon ImageCLASS MF4350d Transformer Replacement: Schritt 3, Bild 2 von 2
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: Schritt 4, Bild 1 von 3 Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: Schritt 4, Bild 2 von 3 Canon ImageCLASS MF4350d Transformer Replacement, Canon ImageCLASS MF4350d Remove Right Side Paneling: Schritt 4, Bild 3 von 3
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
  5. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: Schritt 5, Bild 1 von 2 Canon ImageCLASS MF4350d Transformer Replacement, Transformer: Schritt 5, Bild 2 von 2
    • Locate the yellow wire connected to the metal box.
    • Carefully pull the yellow wire from the black connector.
    • Wires may detach completely from plug so tug very gently.
  6. Canon ImageCLASS MF4350d Transformer Replacement: Schritt 6, Bild 1 von 2 Canon ImageCLASS MF4350d Transformer Replacement: Schritt 6, Bild 2 von 2
    • Locate the spring.
    • Unhook the spring on the side of the metal box.
  7. Canon ImageCLASS MF4350d Transformer Replacement: Schritt 7, Bild 1 von 1
    • Unscrew the 10mm screw attaching the metal plate to the printer.
  8. Canon ImageCLASS MF4350d Transformer Replacement: Schritt 8, Bild 1 von 1
    • Lift the transformer out of the printer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Helena Yanez
455 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 13-1, Forte Fall 2013 Mitglied von Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 15
Insgesamt: 2,795
