Zum Hauptinhalt wechseln
Canon MF4700n Laser Toner Cartridge Replacement
Was du brauchst
  1. Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: Schritt 1, Bild 1 von 3 Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: Schritt 1, Bild 2 von 3 Canon MF4700n Laser Toner Cartridge Replacement, Laser Toner Cartridge: Schritt 1, Bild 3 von 3
    • Turn off the printer.
    • Make sure that the energy saver button is not lit up. If it is, the printer needs to be turned off.
  2. Canon MF4700n Laser Toner Cartridge Replacement: Schritt 2, Bild 1 von 2 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 2, Bild 2 von 2
    • Grab the operation panel and lift it up to reveal the toner cover.
    • Make sure there is nothing on top of the printer.
    • Potential for Device Damage: Forcing the operation panel to open may cause damage to the printer.
  3. Canon MF4700n Laser Toner Cartridge Replacement: Schritt 3, Bild 1 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 3, Bild 2 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 3, Bild 3 von 3
    • Open the toner cover to reveal the toner cartridge.
  4. Canon MF4700n Laser Toner Cartridge Replacement: Schritt 4, Bild 1 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 4, Bild 2 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 4, Bild 3 von 3
    • Grab the ledge of the cartridge and pull it out.
  5. Canon MF4700n Laser Toner Cartridge Replacement: Schritt 5, Bild 1 von 2 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 5, Bild 2 von 2
    • Grab a new/working toner cartridge.
    • If the cartridge is new, then there will be plastic components on it. Follow the manual that comes with the new cartridge to remove the plastic components.
    • Shake the cartridge to distribute the toner evenly inside.
  6. Canon MF4700n Laser Toner Cartridge Replacement: Schritt 6, Bild 1 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 6, Bild 2 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 6, Bild 3 von 3
    • On both sides of the cartridge, there are two knobs sticking out.
    • Inside the toner cover, there are two toner guides, one on each side.
    • Align the knobs with the toner guides and push the cartridge securely all the way in.
  7. Canon MF4700n Laser Toner Cartridge Replacement: Schritt 7, Bild 1 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 7, Bild 2 von 3 Canon MF4700n Laser Toner Cartridge Replacement: Schritt 7, Bild 3 von 3
    • Close the toner cover.
    • Lower the operation panel.
Abschluss
The Canon MF4700n Printer should print normally unless a different component is broken.
Raymond Mach
185 Reputation
1 Anleitung geschrieben
York University, Team S1-G21, Woodhouse Winter 2021 Mitglied von York University, Team S1-G21, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G21
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 54
Insgesamt: 1,392
