Einleitung
Use this guide to replace the button pad.
Was du brauchst
Orient the camera so that the back button panel and viewfinder are facing you.
Push the "Battery Release" button to the side and hold.
While holding the battery release button to the side, slide the battery towards you, past the release button.
Orient the camera with the hand strap facing you.
Remove the two 4mm #00 Philips screws.
Orient the camera so that the viewfinder is on your left and the lens is on your right.
Remove the 4mm #00 Phillips screw.
Reorient the camera with the back button pad and viewfinder towards you.
Remove the three 4mm #00 Phillips screws shown on the rear face of camcorder.
Remove the plastic cover from the rear of the camcorder by gently pulling it towards you while holding the camera as shown.
Remove the 4mm #00 Phillips screw located to the right of the LCD release switch.
Open the LCD by using the release switch.
Reorient the camera with the playback button pad and edge of LCD screen facing you.
Remove the 4mm #00 Phillips screw shown.
Reorient the camera with the top facing you. The side with the LCD screen should be on the right and the other side panel should be on the right.
Open the pop up flash on the top of the camcorder.
Reorient the camera with the bottom facing you, LCD screen on the right, side panel on the left.
Open the tape deck by sliding the switch and moving the deck cover to the left as shown.
Reorient camera with lens facing you.
Remove the #00 Philips 4mm screw shown on the hinge of the tape deck cover.
To remove the camcorder lens hood, twist the hood to counterclockwise and it will come loose, then pull towards you.
Close the tape deck by gently pushing it toward the body of the camera.
Slide and remove the plastic cover on the bottom right, exposing the interface shown.
Reorient the camera so you are looking at the side of the camera with the viewfinder on the left and lens on the right.
Holding the camera as shown,remove the 4mm #00 Phillips screw.
Reorient the camera with the lens facing you.
Gently pull the side panel of the camera to the right to remove.
Remove the #00 Philips 3mm screw as shown holding the small circuit board on the side panel.
Remove the circuit board you just unscrewed. It is the black rectangle that says "CAUTION" on it.
