Einleitung
Use this guide to replace the broken buttons to get back full functionality of your printer.
Was du brauchst
Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
Remove the blue lever from its slot by pushing it back and twisting clockwise.
Close the scanner compartment and cover.
Flip the printer over so that the bottom of the printer is facing you.
Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
Use the plastic opening tool to loosen the side panel from the bottom of the printer.
After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
Remove the ribbon cable connected to the backside of the plastic button assembly.
Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
Gently lift the spring and pull the board out of its plastic button assembly.
